problems ecporting to png CC3 & Windows 7
Hi
When trying to export a map to png format, or indeed any other format, I am finding that CC3 simply stops responding and eventually just craps out, if the quality of the export requires more than 3 passes.
I am running CC3 on Windows 7 with 8Gb of RAM
Any suggestions?
Mel
Any suggestions?
Mel
Abti-alias and quality both set to 75%. However, I found a suggestion to print to pdf in the support pages. that is working, and from PDF I can take it into photoshop and play with it there. A reasonable work around!
Mel
You'll wish to reduce that anti-alias value though. To be able to do anti-alias, CC3 must export a larger image to use when computing the anti-aliasing, and with an anti-aliasing of 75%, it means that CC3 must generate an image 16 times larger than your requested export size to accommodate this. I prefer to never go above 25% antialias, which results in an image 1.78 times as large being generated. Reducing the antialias further allows for a larger final image to be possible.
