Fractional Terrain: What is Enter Setting Name
I am trying to take a fraction terrain map and save it under CC3 but when I do so it asks for Enter Setting Name. I have no idea what this means or what I'm suppose to enter. Please advise me on this matter.
Thank You
    I do File -> Export World -> Cosmographer template.
    I then name it.
    Is that what you are doing ?
  • No, that isn't the path I uses. Instead of hitting Export World ..Cosmographer template...I hit save campaign cartographer 3 File...it then goes through several other things eventually leading me to Enter Setting Name. Then it won't accept anything I type.
    Perhaps a better question is how do I save my Fractional Terrain map to CC3 so I can start to use that program on the FT map?
    The enter settings name prompt appears because you are clicking the 'Create button', thus defining a new export setting to use. The reason why it won't accept anything is probably a permission problem. Try starting FT by right clicking the shortcut and selecting "Run as Admin".
    Anyway, to actually export your map to the CC3 format, select an existing setting and click the Export World button, not the Create button.
