Scale to print in CC3
I was wondering, how would i print out the map, with hexes to the scale of 3 inchs from side to side.
I been test printing and it comes out to large, or too small. Large as in one page is a hex, small as in a quater of the map is a page. Any help would be appreciated. Thank you in advance.
Grid spacing is 50, set up horizontal.
    edited October 2013
    Is this an overland map?
    If so, you should get the desired result by setting Paper distance to 3" and drawing distance to 50 in the print dialog (also remember to activate the "scale factor" instead of "Fit to page" option) [Type the value exactly as provided. The print dialog does understand the inch symbol]
