Symbol Catalogs Meltdown
I'm working on a series of maps and earlier today I opened up the 13th Age vegetation catalog from the September 2012 Annual in the sidebar & placed trees on the first map. I then went to a series of appointments at the VA Hospital. I cam back started up my computer & set to work on a new map in Profantasy using the same parameters. Everything works perfectly until I opened up the symbol catalog for 13th Age vegetation. I now get the message: "No Symbols Available in this style". So I went to open up the first map that worked properly & got the same message. I rebooted & re-installed the September 2012 Annual & still no luck!
What's going on & how do I fix it, please. Plus I'm on an emergency time-constraint on this project.
Sköl, & thanks in advance for any help
Sven
    There are no vegetation symbols in the 13th age style. All vegetation are drawn using drawing tools, not symbols.
    However, I did notice that the master filter setup for the template included a setting for annual issue 64 as well, could it be these symbols you have used? (To get to them, right click symbol style toggle, select Master Filter settings, place a checkmark in the CA64 filter box, hit OK, then click the vegetation button. [To get back to the regular 13th Age symbols, follow the same procedure, except select CA69 instead]).
  • Weirdly enough I did a restore on my system & I got vegetation in my 13th Age folder. Looking up descriptions I realize now there shouldn't have been and somehow this came over from another annual since the dating was different & before the rest of the 13th Age files. I'm guessing I have hardware issues. I found something similar ultimately that allowed me to finish the job in the time constraint I was under, but just barely.
    Sköl,
    Sven
