Copying a map between layers in Castle Creator
I'm having a bit of a problem. I've been following the tutorial for drawing a castle in Castles! Designer Pro. I've finished the base drawing on the Construction layer and I am trying to copy this onto the Wall layer and have run into a couple difficulties.
1) After I copy from the Construction layer and check the box next to the Wall layer, When I paste, I get the shape of the drawing, but when I click it down, it just disappears.
2) Parts of the drawing itself disappear when I copy it. I've tried to Combine Paths command, but it doesn't seem to work.
Any suggestions.
    edited October 2013
    Sounds weird.
    What happens if you try to open up #Tutorials\Castles\CastlesE05.fcw and try the same operation on that drawing. That file should represent approximately the same spot in the tutorial as you describe you are on right now.
    Also, when copying, always make sure to keep an eye on the command line to see if CC3 requests any kind of information from you.
