FT3: Paint Values - Rainfall - how does it work?
Hi folks - would be glad of some help.
As far as I can see...
Tools -> Paint Values -> Rainfall
...doesn't *do* anything.
What am I missing? Help?
(Actually, the only value it seems you can paint is Climate)
Typically, it's better to use a smaller value and one of the raise and lower tools rather than the set tool. Then you can stroke over the area multiple times and nudge things toward what you're after (increasing rainfall in an area will make it greener, decreasing rainfall in an area will make it more desert-like). The basic editing tools (offset, prescale offset, rainfall, and temperature) all work in the same general way with regards to set, raise, and lower.
When I do this, nothing happens. It must be a software issue. I shall go via support.
