Dock Areas
Has anyone seen any symbols appropriate for dock areas in a fantasy setting using CD3 ? If so where are they ? If not any ideas on how to make decking etc ?
  • Roger, if you go and open up the second catalog (the B catalog) files one of them has a specific DOCK set, i think it's the miscilanious or the walls catalog (i know the actual symbols are in the walls directory) I can't check right this second because I'm installing the high def artwork :/
    I used a dock because there didn't appear to be a bridge in this one like in CD-Pro.
  • DOH just found em thanks Rob - i will keep working on the map and get it posted later.
  • 10 years later
  • Sorry for a major necro-thread here, but this was one of the top search results for "profantasy cd3 docks", and I thought I'd throw in at least one answer.
    I found docks under CD3 Bitmap B - Walls.
    If there are others, please let me know!
    I'm still trying to figure out a good way to find particular symbols in the very large catalog... haven't found a better solution than just "click on everything and look" or googling it.
    Another way to find symbols is to right click the open symbol catalogue to reveal the whole thing across the screen.
    If it's not in that one I quite often open my file browser and search the Symbols folder for something like "Bridge", or "Dock". Having found the actual graphic I know the catalogue file won't be far away. Most usually it is in the parent folder, one step up the hierarchy.
