Quick question about cities and battle maps
I am about to embark on a new endeavor and wanted to know if there are any short cuts involved in what I am about to do. I am going to create a city map and then I want to create battle maps based off of the complete city. Once I have a city map, is there a way to select an area of the map that I can use as a base of a battle map? How would you do this?
Thanks
JSM
Thanks
JSM
Do you want to create the whole city than extract a battle map of any part at any moment (as during game for example?). Short of creating each street with thousand of details (most of them for nothing) and having a fast printer, I don't think there is a solution...
Now if you just want to take some part the city to turn in battle map, there are several methods
1. The JimP method , in short: export the target area to a picture file, insert the file in a new map and trace over it.
2. Save your map under a new name, rescale the map border and erase everything outside, trim overlapping entities to the new border
3. Use the copy to clipboard tool to insert only the relevant entities on a new map
Does it answer your question?
I would create a Battlemap of a Location when i needed it
Thanks for the input.
JSM
JSM
JSM
Ken
JSM
- On the main, city, map draw a rectangle (with a hollow fill style) that indicates the area for your battle map.
- Select File>Save As from the menu.
- Select one of the following options from the Save as type drop-down list.
- Use the rectangle you drew as a guide to choose the first corner of the section you want to export.
- Use the rectangle as a guide again to choose the opposite corner of the section you want to export.
CC3 exports the rectangular section you selected to the format you chose in step 3.This is just a guide. It doesn't actually do any copying.
The Save As dialog box displays.
- Rectangular section BMP
- Rectangular section JPG
- Rectangular section PNG (this is what I usually use)
The Command Line shows Pick first corner:If desired, you can use the Endpoint modifier button to exactly choose a corner of the rectangle.
The Command Line shows Opposite corner:
Again, you can use the Endpoint modifier button to exactly choose a corner of the rectangle.
Jim, please correct me if I'm horribly wrong. It wouldn't be the first time.
~Dogtag
Thanks! That little bit of clarification got me through it. I appreciate all the help you guys - as usual
JSM
My problem is, my mind skips steps as 'obvious' and I don't type them.
JSM
