Fastany Symbol Set 1 Question
Ok I have pick up the first symbol set. The question is this when I use the symbols on maps not created with the map template, the scale of the symbols seems to be way off. For example the map I working with right now is 1,430 miles x 1,105 miles.
If I leave on smart tagging the normal CC3 symbols should be 1.43 for the scale. Now if I use any the come with the symbol set the scale is 1.43 but the size of the symbol it self is like 1/10th the size. Is this normal when using a symbol set outside of the template it was meant to be on? Or is my CC3 installed screwed up?
Now I only have the fantasy symbol set 1 installed, so if CC3 installed is messed up is it just uninstall both programs and reinstall?
Thanks
Viking
