Location of Vert. Dungeon Geomorph fill
I'm making a geomorph (horizontal not vertical) and I'd like to use the dirt hatch fill from the August 2011 annual. Where can I find it to use it as my background fill?
    edited August 2013
    It is located at #Hatch Styles\Ca56 Background.FCW
    To use it in any map, click the All drawing tools button, then change the style dropdown to 'Annual Vertical Geomorphs'. You should find the relevant drawing tool here.
    You can also create your own drawing tool. If you do, note that since this is a hatch style, it must be set as the fill style for the outline, not the main entity (The main entity can use a solid color or bitmap fill for the background)
