CC3 on New nVidia 780m Laptop
Hey there, this is more of a technical question. I recently purchased a laptop with the 780m nvidia GPU, but I find performance of CC3 is far slower than my year old desktop. Is this a result of the mobile Optimus technology or am I barking up the wrong tree?
Basically the rendering when I turn on effects plummets, even more so than my desktop using a 550 Ti.
I'm happy to provide more information if it helps solve a larger problem, though I'm not exactly super computer literate.
Thanks!
Thanks!
Would it matter at all if I installed it on a solid state drive or a standard platter, too?
Thanks for the input nonetheless!
CC3's effects cause a bit of a performance hit, causing the display to slow down by up to a factor of hundreds, depending on your screen resolution. Doubling your screen resolution, for example, will usually cause performance to drop by a relative factor of four. I have found that it's a good idea to turn effects off for working on the map and only turn them on to see the final result. That's especially true for the performance hogs like the lighting filters.
On Monsen's note, I recently bought a new laptop for my gf based on the fact it was a Core i7... turned out to be a very mobile version (2 cores, 4 threads, 1.9 GHz). Lesson learnt; next time I'll double-check the processor specs.
I'm thinking there's really not much that can be done but keep effects off and say nice complimentary things to my laptop to keep up its spirits.
