Posted By: TallingrothThanks, I use my phone as a hotspot and for whatever reason it isn't getting to dundjinni
It wasn't your phone. The Dundjinni site was down for a bit after my original message. You should be able to get these symbols now.
As for the strength of the candlelight, you can brighten things up by adding flame symbols to the chandeliers and making the flames semi-transparent to determine the exact brightness of the flames. See the sample below, modifying a chandelier symbol from Greg Taylor to add stronger flames.
Thanks. I figured I could add stronger flames but I thought someone probly spent a lot of time figuring out how much light a candle should emit compared to sconces and whatnot so I would go with the flow, and like I said, my ninja is really going to appreciate that.
http://www.dundjinni.com/forums/forum_posts.asp?TID=10884&KW=chandelier
and here:
http://www.dundjinni.com/forums/forum_posts.asp?TID=6504&KW=chandelier
http://www.greytale.com/wp/?p=1089
http://www.rpgmapshare.com/?q=search/gallery/chandelier
Greg Taylor (Greytale - 1st address above) has a rather primitive looking chandelier that we find useful for taverns and public rooms in inns.
http://www.greytale.com/wp/?attachment_id=1093
And wow, using the lighting effects 24 candles don't make near as much light as I expected. Just means the ninja in our group has lots of options.
Are you still looking for this?
