Noob needs help
Hi,
Iam new here. I finally bought the ''Master Mapper'' bundle after 2 to 3 months of waiting until my tax return finally was deposited on my bank account ^.^
Now I have expierence with some other art programs like photoshop and illustrator so most of the stuff i can figure out by the try and error methode.
But I have two problems (up intil now) i cant seem to figure out... Not even when i look into the Manual :P.
The first one has to do with Chracter artist pro.
Whenever iam making an character, some symbols, weapons or body parts seem to get on top no matter what.. How do i fix this?
And as soon as i started working with Character artis pro I couldnt seem to find my way back to Campaign Cartographer 3 to try and make a map...
Please help? :P
    For the CA symbols, they are set to automatically go to the appropriate sheets, so that the entities appear in the correct order. If this order is wrong, use the LIST command on the misbehaving entities to figure out which sheet they are on, then check in the Sheets & Effects dialog to make sure that sheet appear at the correct spot in the ordering. You can also use the change properties command on the placed entities to change their sheet
    To get back to CC3, simply start a new map, and select an overland map type from the new map wizard. This should set the menus and toolbars correct for overland mapping. The same should happen if you load an existing overland map. Alternatively, there should be a button for CC3 at the end of the file toolbar (along with buttons for each installed add-on that has their own menu set)
