FT to CC3 with Sheets? - Help
Hey gang. New member - but I've been playing with Fractal Terrains and Campaign Cartographer for quite awhile. Generally, I've always used the two programs separately (using CC3 for mapping RPG locations for a fantasy game I run, and FT for quickly creating worlds where more specific mapping isn't necessary - mostly for a sci-fi game I'm in). So I don't have a lot of experience using the two programs together.
However, I ended up sort of accidentally building a world map I REALLY love for an upcoming fantasy game in FT. What I want, however, is to be able to take the continents and map them as I normally would in CC3. The problem I'm having is that whenever I create a CC3 file of one of the continents, I get more of a 'picture' (everything on the 'common' sheet). But, like I said, I want to map it as if I were creating an overland map from scratch on CC3, where the continent is on a LAND sheet and the ocean is the map background, and all the other sheets can be created as per a standard overland map. Is there any way to do this, or am I going to just have to try to create the map from scratch on CC3?
Thank you so much for any help.
Perhaps it will help you, the code is not too hard to edit if you know the colors numbers of your export.
