Prescale Offest Not Working
Hey guys, I'm having a trouble using the prescale offset tools. I imported the etopo1 binary data file and got it working, but when I attempt to use the prescale offset tools (with the check box enabled), they don't seem to work. Anyone have any suggestions? They tools work just fine when I create a new fractal map.
I don't know a way to get the same sort of effect with binary input data, because the continental shelves and other effects are already in the data and can't be just hacked together the way that the continental shelves on the fractal things are. FT's fractal altitude computation is altitude=((prescale + fractal) * roughness + offset), while its altitude computation when using a binary input file is altitude=input_file. After Burn Into Surface is used, the roughness channel is set to 0, meaning that the computation is altitude=offset because the (prescale + fractal) term is reduced to 0.
