Maybe if you are a bit more specific in what areas you need help with, it might be easier to give you advice. Also, if you have a map in progress, posting it here will make it easier for people to see what you are trying to do, and give you appropriate suggestions.
thanks, I'm trying to build an island that is actually the submerged top section of a volcano. The outer sections will be mountainous with a lot of interior ledges and cliffs. the inside with some smaller mountains, and hills as well as a lake to the rear (the volcano's vent point). The whole thing is set up to smaller islands around it and reefs littered through out the area. the city will be built on the interior limited entrance and exit.
