Help with editing the path of an inserted file
I have a map with an inserted bmp file, however, I want to be able to work on this map on multiple computers. When I transfered the map + bmp over, the image was no longer found. I think this is due to the pathing and not having selected "path to map." However, I've been unable to figure out how to edit that. I found a suggestion from five years ago about using the edit tool for it, but was not able to select the inserted file while using that tool.
Any suggestions/help? Worst case scenario, how can I remove the inserted file so I can insert it again in the right manner? I'd rather just change the pathing since the placement is perfect (lined up grid with the image which wasn't that wasy).
