Is there any way to make the Annual Battle tile 10 square by 10 squares? If not, what should I do to start a new tile set that is 10 squares by 10 squares? JSM
Make a copy of the template (CC3/Templares/Dungeon/Wizards/Annual Battle Tiles.FCT) and open it in CC3. You'll have to enlarge the background and grid to match your new size (make sure the show and thaw all layers to really see everything in the template).
Ralf, I tried this and screwed it up many times. Is there any way that you can adjust this for me and post the file here? It sounds like you could probably do this in a matter of minutes as apposed to my feeble poking around. I am looking for a 5 foot square grid with a background that is 50 feet by 50 feet. So where the current template is seven by seven 5ft sections wide, I want ten by ten 5ft sections wide. Can you? Would you? Could you? I would appreciate it enough to send you a virtual Twinkie or something JSM
JSM, here is the edited template (it's a copy of the one in CC3/Templares/Dungeon/ ). Note that all the connector help that Joe set up won't match this size of the tile, and it won't fit on an US Letter page for printing.
Okay, I find myself needing multiple sized tiles, but I'm not sure how I go about manipulating the template to get the sizes I need. In part, I'm looking for ways to make a few overlays that I can use to change up the tiles for a hedge maze I've designed. As such, some of the titles need to be as small as 1" x 1" and as large as 3" x 3" and every size in between. If there are instructions somewhere that would allow me to make the various formats, I would be most appreciative.
~Dogtag
JSM
JSM
