Fractal Terrains 3 New Features
What would your top three new features for Fractal Terrains 3 be? I'm looking for modest improvements rather than anything off-the-wall.
[Edit: Feel free to go for slightly less than modest improvements now]
CC3 properly.
When creating multiple image export. It would be nice if the map level would be a higher resolution generation. What I mean by this is that if you do 5 levels, the fifth level looks real blocky. It would be nice if it was a higher level generation of the terrain.
in CC3 units (say 1000 x 800
If the export could be restricted to visible entities only, that would be even better.
For a not-so-modest improvement, I'll just say Plate Tectonics. The science is now 50+ years old,
and its omission from FT3 really shows.
the CC3 "cut" function to reduce a contour map exported from FT3
is contours that lie within the perimeter of larger, supposedly higher, contours. Probably a side-effect of
exporting with multipolys turned off and then cutting the resultant map, but I wouldn't swear to it. Just forget I mentioned it.
Peter
My current settings are 4096 horizontal and 2048 vertical. I do not remember what the defaults were.
For example, see the map on this Link which is captioned "Interrupted sinusoidal map with asymmetrical lobe boundaries emphasizing lands over oceans, after Deetz and Adams."
http://www.progonos.com/furuti/MapProj/Dither/ProjInt/projInt.html
I believe it may be possible already to do this in FT3 if you know how to write new Projections in some kind of settings file or code? Maybe this can be introduced into the GUI under Change Projection menu? Perhaps with a visual preview showing where the interruptions would occur as you shift the variables?
Thank you for the software and work on improvements.
Dream feature
1) Being able to provide a land mask of my world to FT3 and have it used to randomly generate the land/water topography based on that.
Doable features (I think)
1) Proper export to CC3 using various projections. The current version has issues (distorts) with many projections.
2) I would like it if the (x,y,height) info was displayed for wherever the mouse is. Right now there is no way to tell the height of any point in the map. (This exists in Wilbur)
3) Speaking of Wilbur get FT3 and Wilbur on better terms so no flipping is required when working between them. So in essence proper export of MDR files so that flipping is not required in Wilbur.
4) Use Wilbur-like incise flow in FT3 and provide much better documentation on the settings and how they will effect the terrain.
5) Ocean currents view. In addition to Rainfall, Temperature, Altitude etc. based on the world data could an ocean current map be generated indicating temperature and directions.
2. Erosion based off fluvial, wind and thermal.
3. The ability to define tectonic plates and their directions of movement and alter the globe based off those interactions over time.
4. The ability to define ocean currents.
5. The ability to define weather patterns based off ocean currents, land masses, mountain ranges and tilt on planetary axis.
6. A large spinning spherical global view option.
7. The ability to add basic symbols for cities , points of interest, boundaries, and text on an overlay layer.
8. The overlay layer translating to the CCx export file so the markups can be edited there and given more detail.
It would be nice to have predefined zoom settings that match CC3's or CC3+'s templates so we could cut out a section of the FT world and paste into CC3 easily. Add in a custom scale feature for those of us that do custom size maps.
Although I have FT3 and it's previous version, I pretty much stopped using it. I spent too much time fiddling with raising and lowering things in order to get even close to a map I would consider using. I just started drawing my world maps directly in CC2/CC3 now CC3+. Then I'd use those as the basis for more detailed cutout maps of a smaller region of the world map. If I could draw the basis for the world once in FT and then go back to it to zoom in on a section for more detail in order to export to CC3 that would be ideal. Basically, I want it to export a lower resolution world map and be able to increase the detail as I zoom in on an area that would fit into one of CC3's predefined map scales.
A large spinning spherical global view option is a huge thing for me.
Also, and again, I'm not sure if this exists or not, but I would like to see the ability to create land and water options floating in free air
floating isles
2: High resolution export to Google Earth
3: Make brush tools so they don't clip to a grid
Distant 4th: Make Gaia look better. Tropical Deciduous Forests shouldn't ever appear light tan.
1/ ---- Batch command line
I'm working again with FT3 and something I really need to improve "my" workflow should be a powerfull yet simple (huhuhu) COMMAND LINE capability.
I make planets on a regular basis, not that I map them all (because of the time it implies) but I would if I could. And to achieve this, I would be veeeery happy to be able to batch-call FT from my other softwares (AstroSynthesis to name one).
If the command line could take the existing params plus the following (not exhaustive list), it would make my life better
* choosing a color scheme
* choosing a temp/climate shader file
* choosing LAYERS TO display!!!! (<-- raaaah! I neeeeed this!
* applying several filters (actions>>incise flow/fill bassins/etc.) with power and number of call... make rivers...
Yes, I would be able to control almost everything (but paint tools
2/ ---- Fractal map
Aside of this, another point to me is to be able to have a more detailed "low" view. I have a campaing setting that is played on a rather small island but players are going to go overseen and reach other places arround the world. Thus I have a full planet ready to be mapped BUT my island is quite small and I regret the "fractal" is not actual fractal and at the level of detail I work, I only have laaarge swirls and lines and knots visibles that are supposed to be the lands and coats... And that's quite ugly.
For sure, once exported to CC3, I retake this by making them fractal lines, but, well: because it is not from the original FT file, when I make another map at a different scale, I struggle to get quite same-looking coast and heights.
But I suppose such a "feature" implies a drastic rework of the graphic engine... Which is not the aim of a future upgrade...
Well: you asked, I answered
That are the two main upgrade I would expect from a new revision.
Thanks for your work and that excellent program!
Paul
As far as 2 goes, there's not a whole lot that can be done with the amount of detail available if you're using older fractal function types. The implementation of those types causes them to lose precision past a certain point (usually around 12 octaves). The fractal functions with "improved Perlin's Noise" in their names don't lose precision in this way and you can easily go to 30 or more octaves if you're willing to wait. However, those types won't generate the same worlds. Getting hybrid types (type A to a certain number of octaves and type B after that) has been on the list for a while, but I don't expect that it will hit any time soon.
I'm used to working with "Millieu Sim's Weather Master", importing my FT files to deal with climate for my campaing...
This admirable piece of software is dead ten years ago and today it definitively stops working (not running under Win10).
I would be happy to get all its features in FT, but that's not the point.
At least, if you could have a rather simple and rough climate generator, that would be terrific! I explain:
I have my FT map. I switch to Climate View. I select from the menu bar the brand new "make a day" tool which allows me to select a zone (a pixel) on the map, and - boom! - according to the pixel's climate/temperature/height, I'm proposed a "today's forecast": evolution of the temperature from midnight to midnight, rain previsions, etc."
Because I know about meteorology and astrophysics, I know one would expect a more complexe setting to achieve such a stuff (like planet position according to the sun, way to count time on the planet, etc.)... But... Well...
Just saying. An idea striking my mind just now. Forget.
Regards,
