Lighting Modern Structures
I'm trying to draw a modern structure with skylights and modern lighting fixtures, and need advice on the following issues: How do I
- set up illumination from the skylights using global sun and an overhead mask?
- combine this with internal light sources? Are there any electric light symbol catalogs I could use?
- create indirect illumination sources? (Note: fluorescent tubes are not point light sources.)
- draw translucent skylights on the roof? What fill style do you recommend?
Dalton "needing some light shed on this problem" Spence
As far as multi sheet symbols and posting a symbol manager listing of it, I don't quite follow what you are asking. The rectangle was a normal closed path with a white solid fill. The only symbols I used were the doors.
