Altenberg A city in Jon Roberts style.
After getting city designer this is my first attempt on creating a city map :
City of Altenberg an important city in the heart of the imperium and the seat of the duke of Fuersten and the Arch-Marchall of the Imperium.
I need some help with 1 small problem.
I used some bitmaps from the bitmap A classic style but I couldn't figure out how to extract the roof colors from the Jon Roberts style onto these roofs.
Congratulations.
~Dogtag
added the FCW file KenG
Can anyone help me with this ?
Totally agree with Medio, the main issue with this style are the water and land textures. I'd have to add another 500trees to make it look better.
Is there any solution to remove the tiling?
JSM
This is a beautiful map! I prefer the original version, but a Texture Overblend effect over the blurred land might help with the second version.
I rather prefer the blurred map. I really don't like this repeating artefacts in the other.
On the other hand, it is possible to edit the fill style's scales without resorting to the blur effect (check scaled in the fill style properties dialog and choose higher values).
Scroll down the Fill Style Name menu till you got the fill style you want to edit.
Make sure scaled is checked and see if changing the values will yield better results.
A great map that became even better with good advice.
One ting thing I noticed, just south of the Duke's palace there's a golden dome with a tree seeming to grow on top of it. Though you've doubtless already noticed and fixed it I felt it best to mention it just in case you hadn't yet.
