Floor plans
I'm new here so hi folks.
I've made some city maps with CD3 and used the floor plan tool. However, whichever template I use, there are no matching walls in the symbol catalogue. Also, I can't work out how to change the symbols used for the walls (I can only change the floor). This means that I cannot add any additional walls of a matching style.
I just bought DD3 thinking this will help but I still have the same problem. Any help would be appreciated, thanks.
    Walls are drawing tools, not symbols. When in a floorplan drawing, right click the "Default Wall" button to see the different wall types. (Or click the All dungeon drawing tools button to see all the drawing tools)
    To change the fill style of existing walls, use the Change Properties tool. Make sure the walls are not on a frozen layer. Also note that walls usually are lines, and need to be selected by their centerline, not their outer edge (Usually only an issue if you zoom in, otherwise the pick cursor is usually large enough to pick up the center line even if you click the outline anyway)
