Realistic altitude amounts in FT
If I know the diameter of a world and assuming more or less Earth-like density how can I come up with reasonable max amnd min values for elevation?
    The larger the world, the smaller the mountains should be, especially in proportion to world diameter. Water-saturated rocks have only so much strength (dry rocks are something else entirely; see Venus).
    For any reasonable world size, I would expect that min and max are going to be pretty earthlike (-30000 to +30000 meters).
  • What's a reasonable world size? Traveller generates worlds from 1,000 to 10,000 miles in diameter.
  • Posted By: AlricWhat's a reasonable world size? Traveller generates worlds from 1,000 to 10,000 miles in diameter.
    Size for any world is a moot issue - it's DENSITY that counts - because density determines gravity, and gravity is a key factor in livability.
    A planet can be twice the size of Earth - but if it has roughly from 0.86 to 1.4 times the gravity of Earth due to the density of it's mass, then technically / theoretically, it can have a gravitational pull tolerable to human life, and comparable to that of the Earth's - and could theoretically have an atmosphere like our own without either the atmosphere being too doped with raw hydrogen gas, or too dominated by CO2 (Carbon Dioxide). I weigh 212 lbs., on a world with 0.86 times the Earth's gravity - I would weigh 182.2 lbs.. On a world with 1.4 times the Earth's gravity, I would weigh 296 lbs..
    As far as worlds go - it's density, not size. However - since most rocky terrestrial planets are roughly made of the same stuff, and packed together generally the same - then an "ideal Earth like" terrestrial world would probably be from 0.86 the Earth's diameter, to 1.4 times the Earth's diameter.
  • I'm not so much worried about if the planet can naturally sustain life, this is Sci-Fi after all. I just wanted to know if I needed to adjust the max and min elevations for realistic maps. Sounds like I don't really need to worry about that too much.
  • edited October 2012
    Posted By: AlricI'm not so much worried about if the planet can naturally sustain life, this is Sci-Fi after all. I just wanted to know if I needed to adjust the max and min elevations for realistic maps. Sounds like I don't really need to worry about that too much.
    Nah - but if you make a world - say - three times bigger than Earth diameter wise - then unless it's a world that's density is only about 1.4 that of Earth's - your going to have a planet that has 3 times the gravity. You could pull that off if say - the world in question was honeycombed with so many subterranean cave networks that even though it was 3 times "bigger" than Earth - it only had enough "stuff" substance wise to be roughly equivalent to Earth's density / mass - and had an Earth sized molten core, as opposed to one that was three times larger ?
  • There is a sf story where a planet is huge. I forget how many times larger than the 'standard planet' it was. But here is the kicker. It was hollow, with a small, in mass, black hole in the center. The planet, which didn't appear to be a ring, was basically orbiting the black hole. I remember there being a map of the planet's surface in the book. I also remember, it has been years since I read it, mention that 'advanced technology' kept the black hole from swallowing the world. But the black hole did wobble. Making for interesting seasons and gravity changes.
