Trying to get FT to CC3
Hi all, real newbie question
After watching the tutorial vids, I downloaded the 14 day trial of FT. I've then spent the day building my own world based on an ongoing RPG, from scratch. I really wanted to then spend a lot of time mapping out all the areas in detail so after purchasing CC3 I've been trying to export it with no success (after following the tutorial to the letter) all I get is a limited basic tiny image that appears incompatible with FT.
Frustrated,
please help
    Images exported by the demo version of FT is heavily limited in output resolution. This limitation is not present in the full version.
    To export files usable by CC3, you must use the File -> Save Campaign Cartographer file option. This will export a file natively usable in CC3. If you use the File -> Export World -> cosmographer template, it will insert an image of your wold as the map background for the CC3 map, but this will be limited by the export resolution limit in the demo. Most of the other export options exports file not compatible with CC3, and these are also limited by the demo restrictions.
