Editing Objects in 3-D Starmap
Folks, how do I edit an object in the 3-D star map?
For example, if I decide I later want to change the size of a star, where can I adjust that? Or what about the text size associated with a star? Can I adjust that?
Also, can I trim the map if it's too big? Or export a section?
You need to do the same for the text associated to it.
Regarding the last question, I'd say the easiest is to export the full map and then cut it using The Gimp or another image editing tool.
To export a section of a map, simply select "rectangular selection PNG" from the save as dialog. Once you click save, CC3 will ask you to define two opposite corner in the rectangle that outlines the section you wish to export.
Changing the size of a star is done through the scale command (found in the left hand toolbar set). To change the size of text, use the numeric edit command on it, and in the dialog, hit properties and set the new size.
I don't see anything that says locked....so Im not sure why I cant edit the stars....
But when I click DO IT - I dont see any item that corresponds to the star's scale like 1.0, 2.0 etc..
Now next question for you pros
How do I change the Z dimension? The value above or below the plane? Is that possible to edit?
