CSUAC installation
AKABigBlack
Newcomer
a quick question concerning installing the CSUAC files. my installation folder is C:\ProFantasy, not C:\Program Files\ProFantasy. is there anything special that needs to be changed to install them properly?
HKEY_CURRENT_USER\Software\EvolutionComputing\CampaignCartographer3\AppPath
This points to you active CC3 installation.
the "CC3_CSUAC" folders contain all of the .FSC files. the "BL" folders contain the sub folder structure with the art objects themselves. is this correct? still getting red x's....
Post your map (the FCW file) with your red Xs here, so we can take a look at it.
While your screenshot above doesn't show me the whole directory structure, I can clearly see that you DO NOT have a "BL5_FM8 Pt 2 Vegetation" directory inside the CSUAC directory. My guess is that you have one more level than required, and that this directory is actually inside your BL5Pt2_FM8 directory, OR that your directory is simply miss-named. In other words, the art files are NOT where the symbol manager says they should be.
