Not able to Select a Catalog
I started a new map and everything was working great, got it done and started a second map. When I selected structures the 'catalog file' came up (which it always does--kind of annoying but...). This time, the catalog I wanted 'CC3' filled does not display any icons and if I select the blank, my catalog menu remains unchanged.
I have gone into the advanced area and I cannot get it to come up this way either (allot of the menus are empty as well here). I own allot of the profantasy fantasy software (13 different packages for mapping) and don't know if any of these are causing the issue.
Any ideas on how to get the catalog files to show up again. I can add more detail if needed on what/how I am doing things.
    Is the CC3 Filled structures catalog file still in the correct location (#Symbols\Maps\CC3\Structures.FSC)? What happen if you open it manually using the "Open Symbol Catalog" button?
  • Yes the filled structures catalog file is in the correct location, I just verify that it is in the right location.
    Using the 'Open Symbol Catalog' allows me to open it up and use the symbols, however if I click on the 'Structures' catalog again, I do not have access to the 'CC3 Filled' again. I can manually open when I need it and this will allow me to work around the issue.
    Is this a known issue or is there something I can do to allow me to access through the catalog file (I am not above doing a complete re-install if that is what it takes--if that would fix it)?
    edited September 2012
    I'd run a (repair) install of CC3 Update 10 first (Available from your registration page). See if that fixes the problem. If not submit a Tech Support request. I've not seen this issue before.
  • I ran the repair and it seems to have fixed it. If after using CC3 I get glitched again, I will submit a tech ticket.
    Thank you.
