Local Map of the North in Herwin Wielink Style
Hi,
this is a local map of the north of my previously posted world. Unfortunately I was not able to use the edge fade, inner effect, therefor the borders of the terrains don't look very natural. But besides that I am pretty confident with this map.
The only thing that would make this better is the edge-fade effect. Have you tried messing with the settings...sometimes you need to really increase the edge width to get the effect to show up on larger maps.
there is no quick way to do the coastlines like that. I just made a landmass and edited the coastline 'till it looked like this.
I can not edit or add the edge fade, inner effect. But I'm looking forward to solve this problem and then I will change that on the map.
It's hard for me to tell from the resolution on my computer screen, but are those lakes in the bottom center of the map, in the mountains? Glaciers?
Very nice work.
~Dogtag
@ Dogtag: The things on the bottom of the center of the map should be glaciers
@Mateus090985
No, I haven't. But I might put a slight blur on the sea contours. It would look like an edge fade effect on each contour line.
~Dogtag
@ Dogtag: thank you very much.
I managed to solve my edge fade problem and put some slight fades on the forests.
Here's the new version of the map:
But I like what you accomplished.
