Some problems/questions
I've encountered some small issues so I hope someone can help me here.
I mailed Simon about this too, but since we're in the vacation period, he might be away so I'm putting it here too:
1 Scalebar, compass rose for modern political maps overland aren't correct. I get scalebar with lightyears, even after I re-installed.
I've added a screenshot.
Ferry lines and railway are also missing from the drawing tools
2 My screen goes completely white sometimes when using the zoom function, I have to insert a symbol and zoom again or restart the program to regain visibility.
3 Trace function is extremely slow, is there a way to speed this up?
I'm using the following settings Strength : 25 Depth : 3 Segment Length 0.05 - 0.1
On a normal map size. Does this create too many nodes already?
I tried edit > fractalizing after I did all the tracing but that didn't work very well
Additional comments:
Concerning 2: This sounds like a glitch in the map extents. Does this happen on one specific map or generally?
Concerning 3: Depth 3 is already pretty high, generating many nodes. Especially if you use it on an already fractalized coastline. Is this your setting in the drawing tool, or an additional fractalize command on an existing coastline?
Concerning the other mail I sent, I havent received any reply to that.
2 This specifically happens when I use the modern political annual.
I've re-installed. I'll let you know if I get the same problem.
3 Those were the drawing tool setting.
