Cannot Delete Some Walls in COS
I can right click on some walls/bulkheads and click 'Do it' and the wall is highlighted so I can remove it. But other walls I right click on and it doesn't highlight and are not deletable. What it does do is select the entire deck and remove it completely. I have checked my options and it is already on 'Dialog or Popup'. Can someone help me with my deleting woes? I've been through the mammoth FAQ and can't see anything that helps me. Searching the forums has come up with nothing. It's like the wall wasn't even on the screen, as it says 0 entries found. But I can see it.
Also the undo button is only undoing the last few tasks I did. It has no history.
EDIT: The workaround is to save, close the program reopen it again and I can now select the items. I take it this is one of the hundreds of bugs still in this software.
Do the programmers realise the keyboard has a delete key? Why isn't it used?
type the word list
and select the wall
right click the mouse and select Do It from the menu
That will tell you what sheet and layer the wall is on.
Click on the L: (layer dialog) and unclick the second column, which will unfreeze it.
Everytime I hit the space bar it says Cartographer does not under stand: THE
Where do you type it in?
list
nothing else.
I'll give it a try when I encounter the problem again.
