Symbol links
So I've just installed CC3 CD3 and DD3
When I click on the icons highlighted in red the items highlighted in blue on the left change as expected.
When I now click on the DD3 icons to load up those symbols, instead of getting the list loaded immediately I get this popup
and I can't see the symbols I expect in that list. They do open when launched from the open symbols catalog button. I'm sure it worked the first time I tried then a reboot later nothing. I've made sure I have the latest version installed but it hasn't seemed to have made a difference. Except for when I installed the fireplaces they now appear in the list when I click for furniture, but not the furniture.
  • It looks like your filter settings are wrong. Click on the Advanced Properties button that is in your second image. Make sure the fields in the upper right read as follows:
    Catalog Setting filter: Furniture*
    Master Filter: DD3 Color
    Click OK. When asked if you want to save select yes.
  • edited July 2012
    Doesn't make a difference what I add there. I even tried adding * the only one that shows anything out of those links is furniture and only then the fireplaces I installed later.
    Any more ideas?
    Edit: Turns out a reinstall worked. Not a great answer but at least I'm working again now
