Scaling on map, everything os off.
I have been messing around a bit with the Wielink style from the 2012 annual, but it seems like my scaling are messed up.. Both when loading maps, and starting new (standard 1000x800) All bitmap fills are about must be enlarged to about 300 before it is somewhere near right, and the symbols are off scale as well.
I have probably messed up in some settings somewhere, so I just wondered if there were a reset settings somewhere as it is a bit tedious to resize everything all the time ?
Also: there is no wizard for this style, it only appears in the "make your own choices list". Is that the norm, or is it simply a botched installation ?
THat said, the "Decide settings myself" option IS the map wizard. Are you sure you set the 1000x800 size correctly? Are you using the miles or the metric version of the template?
But I will reinstall and see if that fixes things
