How To - Deletion of accidental Grid overlay on map
                    Hello everyone,
Is there a way to delete a drawn grid on a (dungeon) map ? E.g. if you accidental select the hex grid instead of the square grid or the numbering needs to change ?
I found no direct reference, but maybe some can help me in this issue. Otherwise I have to redraw my dungeon map...
Wouldn't it be practical to use the 'erase' pencil button on the GRID sheet as well ? Strange thing is, even if you intentionally don't select the Labelling function to not display numbered values on top of the map, instead the program will add numbers to the map.
If you do delete the grid sheet, you will need to manually reorder the sheets after adding a new grid, to make sure the grid is drawn where it is supposed to be in the draw order.
About the Grid labelling. When creating a square grid, turn on labelling, then uncheck the two "Labels outside" and "Labels in cells" checboxes, before finally turning of labelling again. This will enable you to make a grid without any labels.
