Need help with 'save as'
I'm trying to save a map using save as file type rectangular section JPEG. When I select this file type or any of the rectangular section file types and hit save, the window closes but I don't get a jpeg file. I have no problem using just the plain jpeg file type but the file I get using this type doesn't work as well for what I need. Anyone know how to fix this. Don't know if its relevant but my OS is windows 7 64-bit.
Thanks for your time,
Kirk
Kirk
Jpegs are crapola. They were popular back in the early 90s - but .PNGs are pretty much replacing both Jpegs and GIFS, because they have the best qaulities of both - and none of the weaknesses. You can't do transparent self contained images in Jpeg either. Honestly I don't know why jpegs haven't gone the way of vinyl music records, VHS tapes, and Disco.
If they could find a way to "lock" an image into jpeg - to where you could not convert it into another format - then they would have an even better anti-piracy tool than watermarking, because the more that you saved and resaved that image in it's locked "jpeg" format - the more that the image would fall apart like wet toilet paper.
Thanks very much. That is exactly what I was not doing to complete the process. It helps to know the whole process.
Hellion
The one thing you should also be taking away with you from this: ALWAYS keep an eye on the CC3 command line. It always prompts you for what you need to do next. If you start a new command while the command line still have "questions" for you, the previous command (in this case, the save as [rectangular section] command) will be aborted.
