Export Options - Want To Understand
Ok its is a simple question. As my pc cant handle very high exports, I want to know what is best. I normaly put the Antiallas to 50% but I read someone say that more than 25% is a waste. So if I want more definition is better to turn my Antiallas down to closer to 25% and turn the Maximum Dimentions to a higher number?
    Yes. You can also reduce anti-alias below 25 too. When you use anti-alias, CC3 needs to export an image larger than the final result, in order to apply the antialias. So the smaller the anti-alias value is, the higher you can set the export resolution. Basically, try to find the lowest value for anti-alias you can live with, to get the highest possible definition. Note that you may consider simply exporting with no anti-alias on at all as well, it is not required to use it. In some cases, the added resolution is worth the loss of anti-alias.
  • Ok. Thanks Monsen. I will give a try and see what is the best for me.
