transform a Jonathan Roberts style map in a Herwin Wielink style?
Hello,
is it possible to transform a card(map) made with the style J.Roberts in the style of H.Wielink?
thx
    I haven't tried out the new H. Wielink style myself, but usually, converting between styles requires you to switch the map style in the drawing properties, then use Change Like Draw Tool (Right click the change properties button) to change the various polygons in the drawing into the new style. Then you can use the symbol manager to replace old symbols with the the symbols from the new style.
    However, do expect a fair bit of manual work to make this work properly. Some styles are easy to convert between, others are more difficult, usually because they use special techniques to get the desired result, not only different fills and symbols.
