Need to reset Fractal Terrains
                🖼️ 280 images Departed Legend - Rest in Peace
                    Hmm. I did something, and now all I get are blue worlds, with some elevations. I checked the continental shelf and its set at minus 999 feet. Ocean depth is minus 30,000 feet. The small globe above the quit button on tyhe right shows the regular land colors, but the map generated doesn't.
I think it has to do with me using the moonlike setting, but I cannot get it to go back to Earth settings. At least, I think this is the problem.
thanks !
thanks !
It seems FT is using the saved settings (instead of the current ones) each time you generate a new world, and it only updates the saved settings on exit.
You may also try to uncheck the "Load last setting file on startup" in edit -> preferences, and then restart FT.
I also tried importing a data set. Its all blue.
