Two (I'm sure simple!) questions...
Hi all,
I'm going through the learning curve on FT and CC3 -- and ran into an issue I could use some guidance on...
First -- I was able to take my original campaign map and set it up as a background image to trace over. And, I got all the tracing done. But now, I can't seem to figure out what I need to do to get rid of the original trace image. Can someone guide me?
Second, I'd love to bring a trace file into FT and "build" up the landmass from there. Is this possible?
Thanks in advance, and if you could keep your answers to first grade level in CC, I would really appreciate it!
Brennan
Brennan
Here are a couple tutorials that may help with FT3:
Transferring a CC3 Landmass to FT3
Recreating an Existing Map
You can hide all and freeze all the other layers. Then delete the one item not frozen/hidden.
