Is it possible?
What I am trying to figure out is if it is possible to import a section of a FT3 world (region map) into CC3 and then convert it to an existing map style. I'm not terribly familiar with how CC3 works, but I can follow directions if they exist. I can already select the area I want in FT3, and exoprt to a CC3 file, then open the file in CC3. What I am trying to avoid if possible is tracing the landmass, and drawing rivers by hand. I can add everything else once this is done. Any help would be appreciated.
Mateus
Note that to use this method with an FT-export, you'll wish to use a rather basic export, such as coastline only, as you definitely do not wish to having to manually do this to each contour line.
