Cosmographer Traveller Sector Import not working?
Is anyone else experiencing problems with the Traveller sector import template in Cosmographer 3?
The import wizard displays and I can select sectors fine. The blank sector map appears and then nothing loads.
I've ran the update file for the sector update and made sure I have .Net4. It actually creates the sys_traveller.scr file OK, so I'm not sure why it isn't loading into the blank sector template.
Any ideas?
Any ideas?
I have to manually run the script file created with Tools -> Macros -> Script File and select the sys_traveller.scr file created.
Is this something new as it's not mentioned in the documentation?
Love the look of the sector when the effects are turned on!
Inside CC3:
Go to menu File->New…
Pick Cosmographer with Decide settings myself then click Next.
Select Map Style: Traveller Sector Import and click Next.
Click Finish.
Pick the save you want for the new map.
You should get the import dialog now.
I have since reinstalled Cosmographer 3 and it works fully now. Looks like the Cos3_TravellerImport.exe (ran as Administrator) didn't work properly for me.
All good now though...
