very slow redraws
Hey All.
I've recently re-installed all my profantasy software onto a new quadcore computer (Q6600) - overclocked to 3 GHz. Oddly enough, redraws seem to take a very long time - much longer than on my old P4 processor. Is this software able to fully use the quad-core architecture, or is that ability soley determined by Windows (XP Pro)? I'm not aware that I changed any settings from what they had been on the old computer. Any thoughts on this? tf
You should be able to check this using the task manager. Just see how much of the total CPU CC3 max out on when doing heavy operations. If it maxes on 25% (or 100% on one core, 0% on all the others), it is only using one core, and thus only 25% of your capacity.
Follow these CC3 commandments:
When tweaking effects, keep the Effects on.
At all other times, switch them off.
You only need effects on when you want to see how the map will appear to others. When designing the actual structure of the map (where furniture or mountains go, or whatever), you don't need them.
