Cutting and pasting between maps
                    Hello, all.
I'm feeling a tad dim, here. I created a map in CC3 and am quite happy with the continent and surrounding islands. However, I'm not as thrilled with the template I chose. Not seeing a way to change the template (and assuming that it's a one-time choice when creating the map) I figured I'd cut to the clipboard and then paste into a new map with a different template. However, it appears I'm doing something wrong.
I hid the other layers, so only the LAND and common layers are showing. Then I right-click on the COPY icon, choose COPY TO CLIPBOARD and then drag a square across the map, which selects everything there. I then right-click and choose DO IT. Then I Create a New Map using a different template. However, when I attempt to paste to the new map, I get an error message indicating that the clipboard is empty.
Can anyone suggest what I'm doing wrong? Thanks.
Can't wait to get some mapping done! =)
