Learning through questions...
veilheim
Newcomer
Hi all,
I just purchased CC3, Cosmographer3 and FT today for some work I'm doing building a sandbox Sci-fi environment. I'm liking what I see so far, but (not surprisingly) am feeling a little overwhelmed. One of the first things I would like to do is get my "sector" down on paper. I know, it's hard to believe, but I'm not playing Traveller, and would like to use a different scale on my sector maps. Is there a way to create a template that enables a 20x20 hex map rather than the sector map? Also, even if that's not readily doable, I was wondering if someone could help explain why when I select the Cosmo template and try to define my own settings with the sector map, I end up with the deck plan "template" every time? I don't think I'm smoking crack, but you never know, I suppose.
Thanks in advance,
-V
Thanks in advance,
-V
Of course. Thankfully, by asking me, I figured out what I was doing wrong. In most applications, there's really only one setup screen... so I didn't notice the next versus finished. When you click finish after the first screen, it creates that result. Therefore, don't do that.
Brennan
