never desert in FT 3
I'm new here, trying to make a fantasy world starting with FT 3.0.12 --- I've got the world settings mostly Earth-like (circumference 25000, axis tilt 23.5). My problem is that deserts never appear, despite the Sea percentage being 12. Even when I raise the base temperature to 99 and drop the annual rainfall to 20, I still get no deserts at all.
I understand that I can paint in deserts; my issue is that I don't understand why they're not generated for me. What am I doing wrong? Thanks.
If you go to the Menu Map->Show Other Shader->Show Image Climate. It will open a dialog box with the climate information in it. If you cursor over the desert area, it will tell you temperature and rainfall amounts that it expects.
Second, I have FT 3.0.12 so the "Show Image Climate" choice is directly under the "Menu" menu tab --- there is no intermediate "Show Other Shader" choice. I mention this purely for the benefit of other newbs reading this in the future.
Third, I followed your advice and tried different combinations of various World Settings values, including "Rainfall" (base and random), "Temperature" (both Earth-based and hard-coded base/random/variance), and "Percent Sea" (under Primary). But no matter how many I attempted, I never got the result I wanted --- a world with all possible climates. In particular, I could not get both desert and evergreen forest.
Finally, I ended up using the combination that got me the closest (12% sea, temperate 99:16:90, rainfall 32:64) then painted in the deserts I wanted by defining the exact area via the freehand selection tool, then using Tools -> Global Set -> Rainfall Value to zero out the rain. Instant desert! I did try using Tools -> Paint Value -> Climate method, but the little brush would only apply a tiny little bit at a time, and I wanted large deserts.
This is an extremely nice tool, and I believe that almost all of my problems are due to my inexperience with it. Except it would be nice if the World Settings dialog box would close when I press the Esc key ;-)
Thanks again, Torg.
