Is this map possible with CC3?
Hola folks,
New to CC3 (still) and came across this wonderful map. I would like to use this type of map for my campaigns and was wondering if this type of map is possible with CC3, City Designer, Dungeon Designer, or Fractal Terrains? - the programs I have.
thanks.
thanks.
As a starting point, see this style in the Annual Vol 1 for example:
It uses a similar layout, but a very different style.
Google or do a Yahoo search for old world maps, or look around over at Wikimedia Commons for a good old Public Domain map to use as an overly / template / layer.
Below is an example of a map that you can edit to use as an overlay, I found this map on the net - it's watermarked by a dealership that sells prints of old maps - but if you were to find an image of the map without a watermark, then it would be Public Domain because of it's age. This is just an example of what you can find out there.
When selecting a projection to use in FT3 - make sure to choose one that causes the same types of POLAR distortions that you would see on one of these old maps. You could even create seperate FT3 maps of your world - one of the EASTERN hemisphere, and one of the WESTERN hemisphere (both maps being properly distorted), paste them down side by side on a fresh white background in Microsoft Paint - then overly a border made from an old PD map on top in a seperate graphics app (like The GIMP or Photoshop). I would like to do a tutorial on accomplishing this kind of thing - but it would have to be a bit in the future because I am very busy with other projects and also with personal and business life stuff to.
By the way - you can do this stuff with FTPRO 2.3+ if you don't have FT3.
All in all - your not going to be able to accomplish this kind of thing in two or three clicks - but there are definitely several ways to accomplish this. When hunting maps on the net to make into an overlay, try to find some that are pretty big / High Resolution, and output your maps from FT3 / FTPRO so that they are also within the same ballpark size wise.
