Would it be possible to allow use to use PNGs instead of JPGs for the multi-file export feature in FT3? JPGs have some truly horrible artifacts in them.
If you hold down the Ctrl key when bringing up the Multiple Image Export dialog, you can get BMP files (not terribly useful for web stuff, but there's no compression artifacts in them). The program probably ought to allow a choice of file type directly on the UI, though.
