Ruins of the Undermountain
Highland_Piper
Surveyor
I've started to convert Ruins of the Undermountain into GURPS to relive the good old days (with a new system). Before tackling the huge chore of converting the classic maps to CC3 I thought I would give a shout to the community to see if anyone has already done this. I did find a CC2 map of Level One, although I have no idea where I got that from.
If nobody has then no matter I was planning on doing it any ways.
http://undermountain.org/forums/index.php
Here is an example of one of the maps that have been drawn. Looks very nice.
http://www.cartographersguild.com/showthread.php?1733-Ruins-Of-Undermountain-III-(BIP-Project)
The BIP Project looks great but I can't seem to register and they don't seem to think they will ever get it done. Oh well guess I will do it by hand!
I'm going to do these up and get them printed as an A1 poster. I need to run through the forums on properly scaling the map size and how to use the map I create and then convert areas into battle maps. I used to know all that stuff but I tend to forget things quickly.
I'm going to try to keep them close to the original style, although I will probably change the fill style to a type of cross hatch.
It will be nice to have these as CC3 as I am building up my GURPS converted RotUM in Microsoft OneNote.
I will continue to use this thread to post on my progress. When I finish would I be able to share them or is there legal reasons why I would not be able to?
If you make maps detailing levels of your own design, those would be ok to share, but not straight recreations of the original ones.
I seem to have forgotten how to do some things here. It is amazing how much you forget.
I want to be able to print this as a A1 poster : 594 × 841 mm (23.4 × 33.1 in)
What size do I need to make my CC3 map to have the map fit the scale properly? I have saved my scanned image in three resolutions 300 dpi (7016 x 9933 ppi, my standard), 150 dpi (3508 x 4967 ppi) and 72 dpi (1684 x 2384 ppi).
The Undermountain map in the FR Atlas is 1700x2550 drawing units (which represents feet in a dungeon map) in size, so that should be the proper size of level 1. I believe level 2 is the same size, and level 3 is twice the size, if I remember my Undermountain correctly
