Grids
                    Hey everyone,
I am trying to get grids with solid lines to fill my maps in DD3 like that of "Dungeon Blueprints" but I cannot get it done. I am a new user and am trying to follow the Tome of Design, but not getting very far..please help me out.
Kind Regards,
Levi
Kind Regards,
Levi
Thanks for the input. Yet, I am not sure this is the right technique. I have used this before and thought that it was the right one. I have even looked at as a fill, but this isnt right either. I am trying to figure out how Ralf did the following drawing.
Complete details for making this kind of map is in the December 2007 Annual.
1) Start New Map based on a Dungeon Style (Check)
2) Erase everything on the map (Check)
3) Create a Blue Rectangle of 1000,800 (Check)
4) Create Subfolder named Annual Blue Dungeon (Check)
5) Copy Two Tools in to new folder (Check)
6) Under Drawing Properties Select Annual Dungeon Blue, Set Text Sheet, Save (Check)
7) Under Cutoms Drawing Tools Click Advanced; Create Simple White Polygon in tool called Floor, Default ( I think I did this right, so Check)
8) Create tools for Cave, Default and Floor, 10' Corridor (Again I think I did this right, so Check)
Here is where it gets confusing: add a 10’ Square Grid with the Hex or Square Overlay… command and we’ve got the basic
look of the map down. Draw a few rooms, corridors, caves, etc. to get an example map.
I do this on Grid Layer/Sheet but the grid is Black (I know I can change the properties, but this isn't working); When I Draw a few rooms....I am not sure what tool to use...the Add Room and Add Corridor Tools do not seem to be using the custom drawing tools...so I go to Custom Drawing Tools and select Floor, 10' Corridor and that does not seem to be using the Properties that I set. No matter what tool use I get a blank, hollow object that has black lines, the grid is still all over and it looks nothing like the following.
So I have know idea what I am doing wrong or not doing. Please lend me your experience to get past this.
Levi
The rooms are supposed to be blank hollow objects. I am unsure what you mean by black lines here though? Are you talking about borders around the object, or the grid? If you get borders around the, make sure that the draw tools are set to not have an outline, or as an alternative, an outline in the desired colour (Same as the background colour). If you set the outline to use "current colour", it will use the currently selected colour
Monsen...The black lines I was referring to were the Hex/Grid being originally in black...but with the obvious changes in the color and the layering WHAM it works now....or rather I get it.
Thanks for all your help...I hope that you all are ready for more questions....
1) I select a Symbol of a Stair case, and place it on my map. Once it is there I see the Grid either behind or in front of the symbol itself.
2) when I go to use my tools for drawing rooms or corridors, etc. the Insertion Point is always in the middle...How do I adjust this. I cannot find this in the tutorial, the Tome of Design o rinthe Help File....
. (Current Insertion Point in a 10' Wide Corridor)
I want:
.--------------------- (Ideal location of Insertion Point of a 10' Corridor)
1) Edit the symbol (if this is a problem most of time). Do it in the map itself if it's a recurring problem only in this map, or edit it in the symbol catalog itself if it's a recurring problem on all your maps.
2) Turn off snaps and place this symbol, then turn them on
3) Place the symbol using snaps, but then move it. If you use relative coordinates, you can easily move it to exactly where you want it.
I'm sure other users can suggest additional options.
Steve
Thanks for the suggestions. Unfortunately this is not a symbol, wish it was (though I suppose I could create a Symbol Library)...But this is a Cutsom Drawing Tool (I wasnt very clear about that).
As long as your snaps is set to half the width of your regular corridors, you should be able to easily place the corridors at any position though.
Good Point...I hadnt thought about it in that way. Thanks :)
