Zoom extents, causes "white out"
I am having this odd behavior with a map. When I press "zoom extents" the map whites out and I can't zoom back in to the map. The entire map window is just white. The map originally didn't do this and I'm not sure when it began happening other than I was trimming up some walls/floors to make entries.
Anyone have an idea? I did try to select/remove items outside of my map thinking somehow I had created a room that was huge but couldn't select anything to delete outside of the visible map I have.
If that doesn't help, send me the map (ralf@profantasy.com) and I'll check whether I can fix it.
Attached my map for review in the mean time. You'll need to enable the sheets to see things properly. Thanks for your assistance!
Thanks for your help!
