Scale Bars
I apologize if this has already been addressed somewhere but I was wondering how to add a map scale bar to a map that includes the correct measurements for the map?
Thanks in advance!
Jess
Thanks in advance!
Jess
This is simple to determine though. Simply insert the desired scale bar at symbol scale 1, then use Info -> Distance to measure the length of the scale bar.If it is a decorated scale bar, make sure you only measure the length of the scale lines itself, not including any extra decoration. Once you know the length of the scale bar in symbol scale 1, you can use that the same way I used the value of 100 for the default scale bar above.
You should of course insert the scale bar at a symbol scale, than when multiplied with the scale bar's true length, gives you a nice round number. Additionally, if you look at the default scale bar, it is divided into 5 sections, so you usually want a value, than when divided by 5, also gives a reasonable nice number.
